RUCKUS H550
Product Detail
The RUCKUS H550 is a Wi-Fi 6 (802.11ax) Wi-Fi access point with integrated switch in a wall-plate form factor.
H550 features Ruckus' patented BeamFlex + adaptive antenna technology to deliver high-speed 802.11ax WiFi in a low-profile design that can be discretely installed over a standard electrical junction box. H550 allows a range of wired & wireless services to be delivered in hotel guest rooms, student residences, and multi-dwelling units with just a single cable pull per room and eliminates the need for additional switches and power supplies.
Equipped with four Ethernet ports for in-room access, the RUCKUS H550 can be used to connect a range of wired network devices such as IPtv set top boxes, IP telephones, or networked minibars while simultaneously providing dual band Wi-Fi 6 WLAN coverage and concurrent BLE & Zigbee coverage with dual IoT Radios. An IEEE 802.3af-compliant Power-over-Ethernet (PoE) out port on the 901-H550-XX00 SKU, or a 48V passive PoE out port on the 901-H550-XX02 SKU, allows devices such as IP telephones to be powered directly from H550. The H550 itself may be powered via standard PoE or a DC power adapter. The H550 can be managed by SmartZone, ZoneDirector, Cloud or Unleashed management platforms.- Model Name:
- H550
- Product Family:
- RUCKUS Indoor APs
- Recommended Software:
- Stability Release:
- Base release:
- Technology Release:
- Base release:
Use Coveo
Please Wait...
Use Coveo
Please Wait...
Use Coveo
| ID | Title | Version | Release Date | Edit Date |
| 20210511 | RUCKUS AP Aggregation And Fragmentation Attacks Vulnerability (aka “FragAttacks”) | 1.1 | May 11, 2021 | October 15, 2021 |
| 20230208 | CVE-2023-25717: RUCKUS AP Web Vulnerability (RCE/CSRF) | 1.2 | February 08, 2023 | May 18, 2023 |
| 20230731 | RUCKUS Unleashed Authenticated Remote Command Execution Vulnerability | 1.1 | July 31, 2023 | August 01, 2023 |
| 20231128 | CVE-2023-49225: RUCKUS AP Stored Cross-Site Scripting Vulnerability | 1.0 | November 29, 2023 | November 29, 2023 |
| 20240925 | RUCKUS AP Remote Code Execution Vulnerability | 1.2 | October 04, 2024 | October 11, 2024 |
| 20250122 | Security Advisory 20250122: Multiple vulnerabilities in RUCKUS Unleashed and ZoneDirector | 1.3 | January 27, 2025 | July 21, 2025 |
| 20260313 | AirSnitch Vulnerabilities in RUCKUS APs | 1 | March 13, 2026 | March 13, 2026 |
Use Coveo
Use Original Search
Date:
Date:
Date:
Date:
Date:
Date:
Date:
Date:
Date:
Date:
Date:
