Product Detail
The RUCKUS H350 is a Wi-Fi 6 (802.11ax) Wi-Fi access point with integrated switch in a wall-plate form factor.
H350 features Ruckus' patented BeamFlex + adaptive antenna technology to deliver high-speed 802.11ax WiFi in a low-profile design that can be discretely installed over a standard electrical junction box. H350 allows a range of wired & wireless services to be delivered in hotel guest rooms, student residences, and multi-dwelling units with just a single cable pull per room and eliminates the need for additional switches and power supplies.
Equipped with two Ethernet ports for in-room access, the RUCKUS H350 can be used to connect wired network devices such as IPtv set top boxes while simultaneously providing dual band Wi-Fi 6 WLAN coverage and BLE or Zigbee coverage with an IoT Radio. The H350 may be powered via standard PoE or a DC power adapter. The H350 can be managed by SmartZone, ZoneDirector, Cloud or Unleashed management platforms.
- Model Name:
- H350
- Product Family:
- Ruckus Indoor APs
- Recommended Software:
- Technology Release:
Patches:
RUCKUS SmartZone 6.1.0 (GA Refresh) New AP Model Bundle for R760 Access Point
- Product Codes:
